[GRASS-dev] Remaining shell scripts
Michael Barton michael.barton at asu.edu
Fri Jun 19 11:55:08 EDT 2009
On Jun 19, 2009, at 6:49 AM, grass-dev-request at lists.osgeo.org wrote:
>        scripts/d.vect.thematic/d.vect.thematic
Needs to be rewritten into Python (at least for points/lines) because
the current C module only does areas.
>        scripts/r.mapcalculator/r.mapcalculator
Already replaced in python. Can be discarded
>        scripts/r3.mapcalculator/r3.mapcalculator
Needs to be replaced. Can model after new wxpython map calculator
>        scripts/v.in.garmin/v.in.garmin
>        scripts/v.in.gpsbabel/v.in.gpsbabel
>        scripts/v.out.gps/v.out.gps
Need to be ported to python
>        visualization/nviz/scripts/nviz
Need to port to python and keep until wxpython 3Dviz is completed.
Michael
