[GRASS-dev] Remaining shell scripts
Martin Landa
landa.martin at gmail.com
Fri Jun 19 11:59:14 EDT 2009
2009/6/19 Michael Barton <michael.barton at asu.edu>:
>> scripts/d.vect.thematic/d.vect.thematic
> Needs to be rewritten into Python (at least for points/lines) because the
> current C module only does areas.
Probably better to extent C module rather then porting to Python.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
