[GRASS-dev] postgresql speed
Moritz Lennert
mlennert at club.worldonline.be
Fri Mar 6 05:09:29 EST 2009
On 06/03/09 10:30, Vincent Bain wrote:
>> See also some comments of Radim in [2] under "Attributes".
An important point in the above is:
"Another problem is random access to the data in RDBMS
from an application which is terribly slow (due to communication with
server)"
Most vector modules loop through the cats of the vector map and access
the table cat by cat. This creates the random access problem that Radim
speaks about, with significant overhead in terms of connection costs.
The new module d.thematic.area uses a different model, selecting an
array of cats and values (db_select_CatValArray see line 243 of
display/d.thematic.area/main.c in devel6 branch) and during display
loops through the areas in the map, but gets the necessary values from
this array, instead of connecting each time to the db (see line 139 in
display/d.thematic.area/area.c). Thus the random access is handled by
db_CatValArray_get_value and not by a connection to the db, contrary to
what is done in d.vect.chart for example (see line 91 of
display/d.vect.chart/plot.c). By the way, quite a while I proposed a
modified version of d.vect.chart (d.vect.chart2) which implements the
dbCatValArray model [3] and shows significant speed gains[4], and an
even more general approach where you can launch any arbitrary SQL query
as long as it returns a list of category values and display the features
which correspond to these values. This might allow a more attribute
data-centric management and display of maps (see discussion in [5]).
So, it might be interesting to do an audit of database access in
different vector modules to see where a different approach could allow
speed gains.
Moritz
[2]http://freegis.org/cgi-bin/viewcvs.cgi/grass6/doc/vector/TODO?rev=HEAD&content-type=text/vnd.viewcvs-markup
[3]http://geog-pc40.ulb.ac.be/grass/chart/
[4]http://lists.osgeo.org/pipermail/grass-dev/2006-October/026624.html
[5]http://lists.osgeo.org/pipermail/grass-dev/2006-October/026625.html
