[GRASS-dev] postgresql speed
Markus Metz
markus.metz.giswork at googlemail.com
Fri Mar 6 05:45:12 EST 2009
Moritz Lennert wrote:
> On 06/03/09 10:30, Vincent Bain wrote:
>>> See also some comments of Radim in [2] under "Attributes".
> An important point in the above is:
> "Another problem is random access to the data in RDBMS
> from an application which is terribly slow (due to communication with
> server)"
> Most vector modules loop through the cats of the vector map and access
> the table cat by cat. This creates the random access problem that
> Radim speaks about, with significant overhead in terms of connection
> costs.
> The new module d.thematic.area uses a different model, selecting an
> array of cats and values (db_select_CatValArray see line 243 of
> display/d.thematic.area/main.c in devel6 branch) and during display
> loops through the areas in the map, but gets the necessary values from
> this array, instead of connecting each time to the db (see line 139 in
> display/d.thematic.area/area.c). Thus the random access is handled by
> db_CatValArray_get_value and not by a connection to the db, contrary
> to what is done in d.vect.chart for example (see line 91 of
> display/d.vect.chart/plot.c). By the way, quite a while I proposed a
> modified version of d.vect.chart (d.vect.chart2) which implements the
> dbCatValArray model [3] and shows significant speed gains[4], and an
> even more general approach where you can launch any arbitrary SQL
> query as long as it returns a list of category values and display the
> features which correspond to these values. This might allow a more
> attribute data-centric management and display of maps (see discussion
> in [5]).
> So, it might be interesting to do an audit of database access in
> different vector modules to see where a different approach could allow
> speed gains.
> Moritz
> [2]http://freegis.org/cgi-bin/viewcvs.cgi/grass6/doc/vector/TODO?rev=HEAD&content-type=text/vnd.viewcvs-markup
> [3]http://geog-pc40.ulb.ac.be/grass/chart/
> [4]http://lists.osgeo.org/pipermail/grass-dev/2006-October/026624.html
> [5]http://lists.osgeo.org/pipermail/grass-dev/2006-October/026625.html
Moritz, could this information be placed somewhere where it does not get
lost, e.g. in the wiki here [1] or here [2], or in the programmer's
manual? Using the dbCatValArray model does not break compatibility, it
would simply speed up modules, right? Maybe we can also have a document
somewhere describing solutions for the Vector TODO list plus other
enhancements, or is it better to discuss it in the dev ML?
Markus M
[1] http://grass.osgeo.org/wiki/GRASS_7_ideas_collection#Modules_2
[2] http://grass.osgeo.org/wiki/GRASS_7_ideas_collection#Modules_4
