[GRASS-dev] postgresql speed
Moritz Lennert
mlennert at club.worldonline.be
Fri Mar 6 06:18:34 EST 2009
On 06/03/09 11:45, Markus Metz wrote:
> Moritz, could this information be placed somewhere where it does not get
> lost, e.g. in the wiki here [1] or here [2], or in the programmer's
> manual?
Yes, I'll try to integrate it in the wiki (or if someone else wants to
start, go ahead). I think that it's more an issue for the vector (+
possibly display) modules than the db.* modules.
> Using the dbCatValArray model does not break compatibility, it
> would simply speed up modules, right?
Well, that's something we would have to check, I don't have an
exhaustive enough vision to judge that.
> Maybe we can also have a document
> somewhere describing solutions for the Vector TODO list plus other
> enhancements, or is it better to discuss it in the dev ML?
No, a wiki page is probably a good place, which doesn't exclude
discussion on the ML, but leaves a more permanent trace.
Moritz
