[GRASS-dev] Re: [GRASS-windows] windows qgis-grass: make grass
build with vc or keep a separate qgis-grass mingw build?
Glynn Clements
glynn at gclements.plus.com
Thu Mar 26 18:09:20 EDT 2009
Jürgen E. Fischer wrote:
> > > FMPOV the build system is the real issue not the codebase.
> > The build system is a non-issue, as it doesn't affect the resulting
> > binaries.
> Sorry, I don't see what's your point is here.
My point is that you get the same binaries whether you use GNU make or
nmake, so it doesn't affect the end result, only the method by which
you get there.
> > Maintaining DSW/DSP files (or nmake files) isn't a realistic option,
> > and anything else will be "foreign" on Windows.
> cmake would work both ways. It can produce Makefiles and MSVC projects
> (nmake or DSW/DSP/SLN/vcproj).
> My point was simply, that if GRASS were to use cmake instead of
> configure/make most part of making that happen would be on the build
> system and not on the codebase itself.
>From the (inadequate) online documentation, I can't tell for sure
whether it would be suitable. At a first impression, it appears to be
too high-level. Such systems tend to either require that you use
whatever the system emits without understanding it, or that you
understand the inner workings of the system along with all of its
targets.
It might help if you explain what the problem with the existing system
is, given that GNU make is available on Windows.
