[GRASS-dev] CompileOnWindows finished
Colin Nielsen colin.nielsen at gmail.com
Sun Mar 29 11:23:45 EDT 2009
> - Would it be possible to add GRASS-cairo-functionality for WinGRASS?
>  Maybe under http://www.jkrieger.de/programming/cpp/gnulibs.html or http://inkscape.modevia.com/win32libs/ some mingw-
> packages of cairo?
I've added a couple of packages to the TODO section of the wiki page,
that may work. I haven't tried them personally, so report back if you
find success. I've also opened an enhancement ticket on osgeo4w's
tracker to request cairo and cairo-dev be added to their tree.
> - Is this procedere also working for GRASS7? if yes, could a hint be added to the wiki?
> - Would it be possible to add some hints in the wiki about what to do if compiling a new version of the source-code?
Done and done :)
-Colin
On Sun, Mar 29, 2009 at 5:46 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> hi Colin,
> it's a good work! Compiling on Win Vista Business is working.
> Some ideas:
> packages of cairo?
> best regards
> Helmut
>>I just wanted to announce that the CompileOnWindows wiki entry
>><http://trac.osgeo.org/grass/wiki/CompileOnWindows> is finished and
>>now allows anyone to develop grass on windows (vista or xp) through
>>the mingw/msys system with no dependency compiling and relatively
>>little extra work (thanks to jef for solving all remaining issues by
>>adding the mingw-libs package to the wiki).
>>-Colin
> ____________________________________________________________________
> Psssst! Schon vom neuen WEB.DE MultiMessenger gehört?
> Der kann`s mit allen: http://www.produkte.web.de/messenger/?did=3123
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
