[GRASS-dev] GRASS 7 configure fails on Mac
Markus Neteler neteler at osgeo.org
Mon Mar 30 14:41:49 EDT 2009
On Mon, Mar 30, 2009 at 8:38 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2009/3/30 Michael Barton <michael.barton at asu.edu>:
>> I just did an svn update from trunk and tried to configure GRASS 7 prior to
>> compiling. I'm using the same configure string that worked successfully 48
>> hours ago. But configure failed with an geos-config error (below). Is this a
>> bug, or do I need to change my config string to something different?
> recently geos supported was added, so you need to install GEOS library
> or configure with --with-geos=no.
Should the default be no (debatable of course..)?
MArkus
