[GRASS-dev] GRASS 7 configure fails on Mac
Martin Landa landa.martin at gmail.com
Mon Mar 30 14:42:52 EDT 2009
2009/3/30 Markus Neteler <neteler at osgeo.org>:
> On Mon, Mar 30, 2009 at 8:38 PM, Martin Landa <landa.martin at gmail.com> wrote:
>> Hi,
>> 2009/3/30 Michael Barton <michael.barton at asu.edu>:
>>> I just did an svn update from trunk and tried to configure GRASS 7 prior to
>>> compiling. I'm using the same configure string that worked successfully 48
>>> hours ago. But configure failed with an geos-config error (below). Is this a
>>> bug, or do I need to change my config string to something different?
>> recently geos supported was added, so you need to install GEOS library
>> or configure with --with-geos=no.
> Should the default be no (debatable of course..)?
I was thinking to change it to 'no'. I will do.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
