[GRASS-dev] GRASS 7 configure fails on Mac
William Kyngesburye
woklist at kyngchaos.com
Mon Mar 30 17:50:07 EDT 2009
I looked at configure to see what it's doing for GEOS. Looks like the
geos-config option should be the one. config.log is your friend when
configure fails.
Is GEOS support really using the C++ API? geos-config --libs only
returns the C++ linking info.
Searching the rest of the source, I don't see GEOS used, yet, so there
should be no problems compiling --without-geos. Is this yet to come?
On Mar 30, 2009, at 1:42 PM, Martin Landa wrote:
> Hi,
> 2009/3/30 Markus Neteler <neteler at osgeo.org>:
>> On Mon, Mar 30, 2009 at 8:38 PM, Martin Landa
>> <landa.martin at gmail.com> wrote:
>>> Hi,
>>> 2009/3/30 Michael Barton <michael.barton at asu.edu>:
>>>> I just did an svn update from trunk and tried to configure GRASS
>>>> 7 prior to
>>>> compiling. I'm using the same configure string that worked
>>>> successfully 48
>>>> hours ago. But configure failed with an geos-config error
>>>> (below). Is this a
>>>> bug, or do I need to change my config string to something
>>>> different?
>>> recently geos supported was added, so you need to install GEOS
>>> library
>>> or configure with --with-geos=no.
>> Should the default be no (debatable of course..)?
> I was thinking to change it to 'no'. I will do.
> Martin
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole. Now what
does that remind me of? Ah, yes - life."
- Marvin
