[GRASS-dev] GRASS 7 configure fails on Mac
Martin Landa landa.martin at gmail.com
Mon Mar 30 17:57:55 EDT 2009
2009/3/30 William Kyngesburye <woklist at kyngchaos.com>:
> I looked at configure to see what it's doing for GEOS.  Looks like the
> geos-config option should be the one.  config.log is your friend when
> configure fails.
see ./configure --help
--with-geos takes path to geos-config similary to --with-gdal.
> Is GEOS support really using the C++ API?  geos-config --libs only returns
> the C++ linking info.
No, C API.
> Searching the rest of the source, I don't see GEOS used, yet, so there
> should be no problems compiling --without-geos.  Is this yet to come?
lib/vector/Vlib/geos.c
vector/v.select/geos.c
M.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
