[GRASS-dev] Re: [GRASS GIS] #571: v.db.addcol: fails if path contains spaces
GRASS GIS trac at osgeo.org
Tue May 5 06:37:28 EDT 2009
  Reporter:  pcav         |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  normal       |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by pcav):
 It does not work from the shell either:
 GRASS > v.db.addcol map=incrociata at paolo layer=1 'columns=provina integer'
 ERROR: value <due/paolo/dbf/> out of range for parameter <driver>
        Legal range: ogr,odbc,sqlite,mysql,pg,dbf
 the location is prova due: obviously it parses it incorrectly.
 GRASS 6.3.0.1~gfossit20090217-1 from debian.gfoss.it
Ticket URL: <https://trac.osgeo.org/grass/ticket/571#comment:3>
