[GRASS-dev] Re: [GRASS GIS] #571: v.db.addcol: fails if path
contains spaces
trac at osgeo.org
Tue May 5 06:48:49 EDT 2009
#571: v.db.addcol: fails if path contains spaces
Reporter: pcav | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by hamish):
what does "v.db.connect -p incrociata at paolo" say?
how about "db.connect -p"?
can you edit the script to make the shebang: '#!/bin/sh -x' and
post the output?
I guess it is db.execute making that complaint.
I notice "driver=${$driver}". does ${foo} act the same as "$foo"?
... but db.execute does not have an option list for the driver
parameter so should not give you one. ?
hmmm, was [v.]db.connect set to use a hard pathname instead of
including '$' chars?: '$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
those should stay like $MAPSET and not be exapanded.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/571#comment:4>
