[GRASS-dev] Problem v.in.ascii (GRASS6.4.0RC4)
Moritz Lennert mlennert at club.worldonline.be
Tue May 5 11:40:11 EDT 2009
On 05/05/09 14:07, roberto marzocchi wrote:
> v.in.ascii -z input=fle_input  output=name_output format=point fs=
> skip=0 x=1 y=2 z=3 cat=0 --overwrite --quiet
> Output:
> Segmentation fault
> dbmi: Protocol error
> Grass import correctly the points, but don't create the associated
> table. anyone know the reason?
Is there any attribute data contained in the input file ? It would help
if you sent us at least the first few lines of the data.
Also fs= seems weird. What is the field separator in the file ?
Moritz
