[GRASS-dev] Re: [GRASS-SVN] r37136 -
grass/branches/develbranch_6/lib/gis
Markus Neteler
neteler at osgeo.org
Mon May 11 01:34:27 EDT 2009
On Mon, May 11, 2009 at 1:02 AM, <svn_grass at osgeo.org> wrote:
> Author: hamish
> Date: 2009-05-10 19:02:37 -0400 (Sun, 10 May 2009)
> New Revision: 37136
> Modified:
> grass/branches/develbranch_6/lib/gis/gisinit.c
> Log:
> be a bit more blunt in the error message
> Modified: grass/branches/develbranch_6/lib/gis/gisinit.c
> --- grass/branches/develbranch_6/lib/gis/gisinit.c 2009-05-10 21:07:36 UTC (rev 37135)
> +++ grass/branches/develbranch_6/lib/gis/gisinit.c 2009-05-10 23:02:37 UTC (rev 37136)
> @@ -51,7 +51,8 @@
> G_set_program_name(pgm);
> if (strcmp(version, GIS_H_VERSION) != 0)
> - G_fatal_error(_("Incompatible library version for module"));
> + G_fatal_error(_("Incompatible library version for module. "
> + "You need to rebuild GRASS."));
I added this already in 2008 but Glynn commented like this:
On Tue, Sep 9, 2008 at 12:10 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> This:
> http://trac.osgeo.org/grass/changeset/33327
> + G_fatal_error(_("Incompatible library version for module: recompilation needed."));
> isn't necessarily accurate.
> The error could also be caused by a mismatch between PATH and
> LD_LIBRARY_PATH (or ld.so.cache, etc) if you have more than one
> version of GRASS installed.
> Or it could be caused by a module linking against GDAL, where GDAL was
> built against an old version of GRASS. In that case, it's true that
> recompilation is needed, but it would be GDAL that needs
> recompilation.
> In general, error messages should only report what is known; they
> shouldn't attempt to guess as the underlying cause.
> E.g. if write() fails, then you know that write() failed. You don't
> know that it was due to insufficient disk space unless errno is set to
> ENOSPC. write() can also fail with EDQUOT (quota exceeded), EFBIG
> (maximum size of a single file exceeded), EIO (low-level I/O error,
> e.g. media fault, failed NFS server), and others.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Still I tend to actually have the message improved since the
minimalistic notification regularly confuses people.
Markus
