[GRASS-dev] Re: [GRASS-SVN] r37087 - in grass/trunk/gui: scripts wxpython/scripts
Mon May 11 10:05:59 EDT 2009
Hamish wrote:
> > > > is it really needed in trunk in regards we are
> > > planning to use Python for all scripts?
> Hamish:
> > > AFAIK it is needed whenever non-.exe or .bat named modules will be
> > > run using simply their command name.
> Glynn:
> > It should only be needed for Tcl/Tk (exec and "open |..."), which has
> > its own hacks for .exe and .bat (maybe .com and/or .cmd? I'm not
> > sure).
> > Everything other than Tcl/Tk falls into one of two cases: either you
> > always have to provide the extension (even for .exe or .bat), or it
> > uses PATHEXT and the registry settings (related to ftype/assoc).
> AFAICT for non-C modules in g7 Script.make runs the "$(BIN)/%.bat:"
> Makefile rule (in ScriptRules.make) which creates .bat file wrapper.
> But the helper scripts in $(TOPDIR)/gui/scripts/->$GISBASE/etc/gui/scripts/
> do not use Script.make but still need that step.
Nothing should need the .bat wrapper once Tcl/Tk is dropped.
> > BTW, we need to add .py to PATHEXT; we don't appear to be
> > doing this at present.
> Index: lib/init/init.bat
> --- lib/init/init.bat   (revision 37138)
> +++ lib/init/init.bat   (working copy)
> @@ -102,6 +102,7 @@
>  :wxpython
>  set PYTHONPATH=%PYTHONPATH%;%WINGISBASE%\etc\python;%WINGISBASE%\etc\wxpython
> +set PATHEXT=%PATHEXT%;.PY
>  python "%GISBASE%/etc/wxpython/gis_set.py"
>  if %errorlevel% == 2 goto exitinit
> for gr7 is it needed for all gui/tui modes I guess, not just wxGUI.
> hmph, the above doesn't seem to stick.
PATHEXT gets reverted?
> On linux at least the .py is removed from the script name and the module
> gets installed without extension in $GISBASE/scripts/
> I'm note sure what happens with the g7 WinGRASS build.
It gets installed without the .py suffix, which won't work. I'll
commit a fix once it's tested.
