[GRASS-dev] python grass problems on OSX (Incompatible library
version for module)
Markus Neteler
neteler at osgeo.org
Mon May 11 03:37:54 EDT 2009
On Mon, May 11, 2009 at 8:21 AM, Hamish <hamish_b at yahoo.com> wrote:
> massimo wrote:
>> I removed the graas_trunk source code and re-download a new
>> one and rebuild it using these configure [1]
>> but the problem persists.
> what's OSX's version of ldd called?
> if you run that within the broken environment it will tell you which
> libraries it is trying to use.
Debugging on Mac OS X
The 'ldd' command doesn't exist, but
otool -L
does almost the same job.
Markus
