[GRASS-dev] Re: grass-dev Digest, Vol 37, Issue 33
massimo di stefano massimodisasha at yahoo.it
Mon May 11 05:46:02 EDT 2009
What confuse me is that the command img2rr outside a grass shell,
works fine on grass data too.
maybe it can be the gdal-grass version mismatch problem, but tring the
same command inside a grass6.4 environment (instead of grass7)
i get the same problem.
however i'll try a custum build of gdal, make gdal-grass using grass 7
and try again
Il giorno 11/mag/09, alle ore 11:29, grass-dev-request a lists.osgeo.org
ha scritto:
> massimo  wrote:
>> Maybe thes can help ?
>> i runned ottol -L on the grass modules and on gdalinfo executable
> $ grep '6\.[0-9]' ottol_grass_modules.txt
>        /Library/Frameworks/PROJ.framework/Versions/4.6/PROJ
> (compatibility version 6.0.0, current version 6.5.0)
> I'm not really sure if that's GRASS 6.0 and 6.5 or if something else
> has
> those versions. but maybe it's the gdal-grass plugin that needs to be
> rebuilt for grass 7??
> Hamish
Chiacchiera con i tuoi amici in tempo reale!
 http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
