[GRASS-dev] Re: grass-dev Digest, Vol 37, Issue 33
massimo di stefano massimodisasha at yahoo.it
Mon May 11 05:47:09 EDT 2009
i compared the otool output,
/usr/lib/libSystem.B.dylib  don't match
Il giorno 11/mag/09, alle ore 11:29, grass-dev-request a lists.osgeo.org
ha scritto:
> On Mon, May 11, 2009 at 10:40 AM, massimo di stefano
> <massimodisasha a yahoo.it> wrote:
>> adding the debugging symbols to the script :
> (well, it's just stepwise output - symbols is for binaries)
>> GRASS 7.0.svn (spearfish60):~ > i.img2rr image1=geology
>> + '[' -z /usr/local/grass-7.0.svn ']'
>> + '[' image1=geology '!=' @ARGS_PARSED@ ']'
>> + exec g.parser /usr/local/grass-7.0.svn/scripts/i.img2rr
>> image1=geology
>> + '[' @ARGS_PARSED@ '!=' @ARGS_PARSED@ ']'
>> ++ g.gisenv
>> + eval 'GISDBASE='\''/Users/Shared/grassdata'\'';'
>> 'LOCATION_NAME='\''spearfish60'\'';' 'MAPSET='\''PERMANENT'\'';'
>> 'GRASS_GUI='\''wxpython'\'';'
>> ++ GISDBASE=/Users/Shared/grassdata
>> ++ LOCATION_NAME=spearfish60
>> ++ MAPSET=PERMANENT
>> ++ GRASS_GUI=wxpython
>> + : /usr/local/grass-7.0.svn /Users/Shared/grassdata spearfish60
>> PERMANENT
>> + LOCATION=/Users/Shared/grassdata/spearfish60/PERMANENT
>> + export DYLD_FRAMEWORK_PATH=/var/tmp/XcodeBuilds/Release
>> + DYLD_FRAMEWORK_PATH=/var/tmp/XcodeBuilds/Release
>> + export OSSIM_PREFS_FILE=/Users/sasha/Desktop/ossim_preference
>> + OSSIM_PREFS_FILE=/Users/sasha/Desktop/ossim_preference
>> + /private/var/tmp/XcodeBuilds/Release/img2rr
>> /Users/Shared/grassdata/spearfish60/PERMANENT/cellhd/geology
>> MPI running with 1 processors...
>> ERROR: Incompatible library version for module. You need to rebuild
>> GRASS
>>       or untangle multiple installations.
> ok, so the "bad" is in the /private/var/tmp/XcodeBuilds/Release/
> img2rr program.
> otool -L  /private/var/tmp/XcodeBuilds/Release/img2rr
/private/var/tmp/XcodeBuilds/Release/img2rr:
	@executable_path/../Frameworks/ossim.framework/Versions/A/ossim
(compatibility version 1.0.0, current version 1.0.0)
	@executable_path/../Frameworks/OpenThreads.framework/Versions/A/
OpenThreads (compatibility version 0.0.0, current version 1.0.0)
	/usr/lib/libstdc++.6.dylib (compatibility version 7.0.0, current
version 7.4.0)
	/usr/lib/libgcc_s.1.dylib (compatibility version 1.0.0, current
version 1.0.0)
	/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current
version 88.3.10)
otool -L `which g.parser`
/usr/local/grass-7.0.svn/bin/g.parser:
	/usr/local/grass-7.0.svn/lib/libgrass_gis.dylib (compatibility
version 7.0.0, current version 7.0.0)
	/usr/local/grass-7.0.svn/lib/libgrass_datetime.dylib (compatibility
	/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version
1.2.3)
version 1.0.0)
version 111.1.3)
> Please compare to this output from otool on g.parser:
>> (compatibility
>> version
>> 1.2.3)
>> current
>> version 1.0.0)
>> current
>> version 111.1.3)
> curious if they match...
> Markus
Un allegato HTML è stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090511/a55d51eb/attachment.html
