[GRASS-dev] Re: [GRASS GIS] #598: MacOS X / OpenGL and Wxpython incompatible
GRASS GIS trac at osgeo.org
Tue May 12 02:58:38 EDT 2009
  Reporter:  vince   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  6.4.0
 Component:  NVIZ    |     Version:  svn-trunk
Resolution:          |    Keywords:
  Platform:  MacOSX  |         Cpu:  OSX/Intel
Comment (by vince):
 Replying to [comment:1 kyngchaos]:
 > If you configure with tcltk (for the original nviz), you must use an
 Aqua framework TclTk, since it shares the same OpenGL setting.
 This is impossible for a 64-bit build. Tk-aqua is not 64-bit capable,
 because Tk (even the latest version) relies on deprecated Quickdraw API
 functions that are only available in 32-bit.
Ticket URL: <http://trac.osgeo.org/grass/ticket/598#comment:3>
