[GRASS-dev] reorder tcltk/opengl checks in configure?
William Kyngesburye woklist at kyngchaos.com
Wed May 13 13:06:45 EDT 2009
For bug
http://trac.osgeo.org/grass/ticket/598
configure needs to temporarily strip out 64bit arch flags on OSX for
the TclTk Aqua tests.  To do this, based on the OpenGL setting
selected (TclTk Aqua is dependent on OpenGL setting = aqua), the
opengl test must happen before the TclTk tests.
I don't see anything dependent on TclTk that would be affected if the
tcltk tests are moved to after the opengl tests.
Comments from the configure/make guru?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"The beast is actively interested only in now, and, as it is always
now and always shall be, there is an eternity of time for the
accomplishment of objects."
- the wisdom of Tarzan
