[GRASS-dev] reorder tcltk/opengl checks in configure?
Glynn Clements
glynn at gclements.plus.com
Thu May 14 20:50:20 EDT 2009
William Kyngesburye wrote:
> http://trac.osgeo.org/grass/ticket/598
> configure needs to temporarily strip out 64bit arch flags on OSX for
> the TclTk Aqua tests. To do this, based on the OpenGL setting
> selected (TclTk Aqua is dependent on OpenGL setting = aqua), the
> opengl test must happen before the TclTk tests.
> I don't see anything dependent on TclTk that would be affected if the
> tcltk tests are moved to after the opengl tests.
> Comments from the configure/make guru?
Will NVIZ cope with a 32-bit Tcl/Tk but 64-bit OpenGL?
When it comes to linking NVIZ, the command will include both the
Tcl/Tk linker flags and the OpenGL linker flags. There's no point in
configure testing whether linking a test program against Tcl/Tk works
without certain linker flags if NVIZ itself is going to be linked with
those flags.
