[GRASS-dev] reorder tcltk/opengl checks in configure?
William Kyngesburye
woklist at kyngchaos.com
Thu May 14 21:47:41 EDT 2009
On May 14, 2009, at 7:50 PM, Glynn Clements wrote:
> William Kyngesburye wrote:
>> http://trac.osgeo.org/grass/ticket/598
>> configure needs to temporarily strip out 64bit arch flags on OSX for
>> the TclTk Aqua tests. To do this, based on the OpenGL setting
>> selected (TclTk Aqua is dependent on OpenGL setting = aqua), the
>> opengl test must happen before the TclTk tests.
>> I don't see anything dependent on TclTk that would be affected if the
>> tcltk tests are moved to after the opengl tests.
>> Comments from the configure/make guru?
> Will NVIZ cope with a 32-bit Tcl/Tk but 64-bit OpenGL?
> When it comes to linking NVIZ, the command will include both the
> Tcl/Tk linker flags and the OpenGL linker flags. There's no point in
> configure testing whether linking a test program against Tcl/Tk works
> without certain linker flags if NVIZ itself is going to be linked with
> those flags.
The system frameworks (including OpenGL) on OSX 10.5 are all quad-
architecture - ppc/intel, 32+64bit. Only the deprecated Carbon stuff
that wxPython and Tk rely on are 32bit-only. If the system was all
only 64bit, we'd have a 64bit wxPython and 64bit TclTk by now.
So, when I configure for a quad-arch GRASS (adding arch flags to
CFLAGS and LDFLAGS), it will test the TclTk linking with the same, and
fail to link because 64bit arches are missing.
I plan to add a $(subst) command to the nviz makefile (and a couple
others that link Tk libraries) to strip out the 64bit flags on OSX
when OpenGL aqua is used. I have that worked out and tested (same
thing I used in the wx nviz and vdigit makefiles before the switch to
setup.py), it just needs the configure tk tests to pass.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
