[GRASS-dev] [GRASS GIS] #604: /usr/lib/grass64/etc/grass-run.sh does not work properly when called by gis.m to execute in a external xterm
GRASS GIS trac at osgeo.org
Thu May 14 08:13:11 EDT 2009
 Reporter:  frankie      |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  minor        |   Milestone:  6.4.0
Component:  default      |     Version:  unspecified
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
 PATH=<grass>/bin:<grass>/scripts:$PATH prepending is missing: that causes
 not found errors for all grass commands. Of course it works correctly when
 called within the main terminal window because the PATH is properly
 initialized before.
 If you wish to resize the X monitor, do so now. Window size is
 locked while interactive modules are running.
 /usr/lib/grass64/etc/grass-run.sh: line 29: g.proj -p: command not found
 ERROR: g.proj -p exited abnormally. Press <enter> to continue.
Ticket URL: <http://trac.osgeo.org/grass/ticket/604>
