[GRASS-dev] Re: [GRASS GIS] #604: /usr/lib/grass64/etc/grass-run.sh
 does not
 work properly when called by gis.m to execute in a external xterm
    trac at osgeo.org
    Thu May 14 09:51:40 EDT 2009
#604: /usr/lib/grass64/etc/grass-run.sh does not work properly when called by
  Reporter:  frankie  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  minor    |   Milestone:  6.4.0
 Component:  default  |     Version:  unspecified
Resolution:           |    Keywords:
  Platform:  Linux    |         Cpu:  Unspecified
Comment (by hamish):
 what tool?  r.digit works fine for me (using etch) from the
 Raster->Develop map gis.m menu.
 the profile tool seems to work ok.
 (I tried it because that runs '|g.proj -p')
 if you look in grass-run.sh it has already:
 # workaround for systems with xterm is setuid/setgid
 #  http://grass.itc.it/pipermail/grass5/2004-September/015409.html
 LD_LIBRARY_PATH=$GRASS_LD_LIBRARY_PATH
 export LD_LIBRARY_PATH
 what xterm do you use? is this 6.4.0rc4?
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/604#comment:1>
