[GRASS-dev] Re: [GRASS GIS] #604: /usr/lib/grass64/etc/grass-run.sh does not work properly when called by gis.m to execute in a external xterm
GRASS GIS trac at osgeo.org
Thu May 14 20:51:29 EDT 2009
  Reporter:  frankie  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  minor    |   Milestone:  6.4.0
 Component:  Tcl      |     Version:  6.4.0 RCs
Resolution:           |    Keywords:  xterm
  Platform:  Linux    |         Cpu:  Unspecified
Changes (by hamish):
  * keywords:  => xterm
Comment:
 Replying to [comment:2 frankie]:
 > I mean the Output Tk window of gis.m, where "Run (in Xterm)"
 > can be called.
 ah, yes. I can reproduce the problem in 6.5svn on Lenny.
 > That is not a problem with library search path,
 > but binaries search path (aka PATH in bash).
 yeah my initial thought was that Sid might have introduced some new xterm
 child filtering which now cleansed PATH as well as LD_LIBRARY_PATH.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/604#comment:3>
