[GRASS-dev] [GRASS GIS] #606: WinGRASS GIS.m: broken newlines in
output window
trac at osgeo.org
Sun May 17 03:30:41 EDT 2009
#606: WinGRASS GIS.m: broken newlines in output window
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Tcl | Version: 6.4.0 RCs
Keywords: wingrass gis.m | Platform: MSWindows XP
Cpu: x86-32 |
in wingrass gis.m output the leading newlines seem to be broken. When you
run a command the first couple of letters seem to be hidden. When you
resize the Output window by dragging on the corner (or if you run another
command) the first missing letter appears next to the scissors icon, and
the second missing letter appears at the start of the next line.
see attached screenshot.
I assume it is because gtcltk/gronsole.tcl hardcodes "\n" in a number of
places (e.g. line 231) which needs to be "\r\n" on wingrass.
maybe something like this at the beginning of gronsole.tcl?
if { $mingw == "1" } {
set newline "\r\n"
} else {
set newline "\n"
and then use $newline instead of "\n"?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/606>
