[GRASS-dev] Change in parser behavior?
Hamish
hamish_b at yahoo.com
Tue May 19 22:04:25 EDT 2009
Hamish wrote:
> since a while ago the parser has not liked option names with
> upper case characters. e.g. STREAM_DIR= in r.terraflow. I think
> there was some posts about it, you were not the only person to
> have trouble with addon scripts.
> try changing to r= k= c= and I'm guessing it should work.
> why? I've got no idea & it should probably be fixed before
> 6.4.0 as it (case in point) breaks back-compatibility even if
> none of the standard GRASS modules use it. It is my guess that
> currently r.terraflow will have issues because of it.
refs:
http://thread.gmane.org/gmane.comp.gis.grass.devel/32805/focus=32811
http://trac.osgeo.org/grass/ticket/520 (open bug)
Hamish
