[GRASS-dev] Change in parser behavior?
Wed May 20 03:55:09 EDT 2009
Hamish wrote:
> and option names can start with numbers? (ok, shrug)
Yep; used for e.g. "g.region 3dview=...".
OTOH, r.terraflow's STREAM_DIR= was the only upper-case option name
anywhere in GRASS.
