[GRASS-dev] Re: vector lib compile error in trunk
Markus GRASS
markus.metz.giswork at googlemail.com
Thu May 21 16:57:14 EDT 2009
found it and fixed it in r37344. Looks like I was the culprit :-(
Markus M
Martin Landa wrote:
> Hi,
> 2009/5/21 Markus GRASS <markus.metz.giswork at googlemail.com>:
>> After r37270 I get a compile error in trunk/lib/vector/diglib
>> The portability test in diglib is no longer passed, probably because
>> portable.c and port_init.c have been modified. According to the
>> changeset it (the compile error) doesn't make sense, but I observed that
>> too when I put in LFS support. The files test32.ok and test64.ok must be
>> created anew, preferably after some testing.
>> Anybody else getting this compile error?
> not me on 32bit, LFS enabled. Hm, probably the changes should be reverted(??)
> Martin
