[GRASS-dev] Re: vector lib compile error in trunk
Markus GRASS markus.metz.giswork at googlemail.com
Thu May 21 12:54:00 EDT 2009
Martin Landa wrote:
> Hi,
> 2009/5/21 Markus GRASS <markus.metz.giswork at googlemail.com>:
>> After r37270 I get a compile error in trunk/lib/vector/diglib
>> The portability test in diglib is no longer passed, probably because
>> portable.c and port_init.c have been modified. According to the
>> changeset it (the compile error) doesn't make sense, but I observed that
>> too when I put in LFS support. The files test32.ok and test64.ok must be
>> created anew, preferably after some testing.
>> Anybody else getting this compile error?
> not me on 32bit, LFS enabled. Hm, probably the changes should be reverted(??)
No need to revert IMHO, the changes do not look serious, it was just
documentation and adding const where necessary when I had a look at the
changeset.
BTW, I got the compile error on Linux 64bit, LFS enabled, after make
distclean. test.c may need a close look, then test32.ok and test64.ok
need to be created anew and tested on different systems, with and
without LFS (that's what I did before submitting LFS to the vector
libs). Unfortunately I have currently neither the resources nor the time
to do some testing on my side. I can't really judge how important that
portability test is, a good reason to make sure it is passed?
Markus M
