[GRASS-dev] Re: vector lib compile error in trunk
Martin Landa landa.martin at gmail.com
Thu May 21 11:53:49 EDT 2009
2009/5/21 Markus GRASS <markus.metz.giswork at googlemail.com>:
> After r37270 I get a compile error in trunk/lib/vector/diglib
> The portability test in diglib is no longer passed, probably because
> portable.c and port_init.c have been modified. According to the
> changeset it (the compile error) doesn't make sense, but I observed that
> too when I put in LFS support. The files test32.ok and test64.ok must be
> created anew, preferably after some testing.
> Anybody else getting this compile error?
not me on 32bit, LFS enabled. Hm, probably the changes should be reverted(??)
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
