[GRASS-dev] reorder tcltk/opengl checks in configure?
William Kyngesburye woklist at kyngchaos.com
Sat May 23 10:15:47 EDT 2009
I could try installing autoconf 2.13 in a sandbox, so it leaves Xcode
alone...
On May 23, 2009, at 3:35 AM, Markus Neteler wrote:
> On Sat, May 23, 2009 at 5:40 AM, William Kyngesburye
> <woklist at kyngchaos.com> wrote:
>> There's only the 2.61 from Xcode.  Is that 2.13 an absolute
>> requirement or a
>> minimum?  I don't see why a newer autoconf shouldn't support an older
>> configure.in.
> Because it is autoconf :)
>> I tried the more complete sequence of aclocal/autoheader/automake/
>> autoconf,
>> but got a bunch of missing template warnings in autoheader.
> I darkly remember that I made tests with 2.51 but quickly gave up.
> 2.13 seems to be an absolute requirement.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
