[GRASS-dev] reorder tcltk/opengl checks in configure?
William Kyngesburye
woklist at kyngchaos.com
Sat May 23 13:23:45 EDT 2009
OK, I installed an isolated 2.13 and it works as expected. I guess
I'll keep it around for GRASS.
I updated configure[.in] + some makefiles in dev6 branch so that
configure + compile works on OSX for a 64bit build with a 32bit TclTk
Aqua.
Configure was a bit messy, since the saving of LDFLAGS happens within
the AC test macro.
On May 23, 2009, at 12:06 PM, Glynn Clements wrote:
> Later versions aren't backwards compatible.
> 2.13 was the last version before autotools degenerated into an
> incomprehensible mess.
On May 23, 2009, at 9:15 AM, William Kyngesburye wrote:
> I could try installing autoconf 2.13 in a sandbox, so it leaves
> Xcode alone...
> On May 23, 2009, at 3:35 AM, Markus Neteler wrote:
>> On Sat, May 23, 2009 at 5:40 AM, William Kyngesburye
>> <woklist at kyngchaos.com> wrote:
>>> There's only the 2.61 from Xcode. Is that 2.13 an absolute
>>> requirement or a
>>> minimum? I don't see why a newer autoconf shouldn't support an
>>> older
>>> configure.in.
>> Because it is autoconf :)
>>> I tried the more complete sequence of aclocal/autoheader/automake/
>>> autoconf,
>>> but got a bunch of missing template warnings in autoheader.
>> I darkly remember that I made tests with 2.51 but quickly gave up.
>> 2.13 seems to be an absolute requirement.
>> Markus
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Mon Dieu! but they are all alike. Cheating, murdering, lying,
fighting, and all for things that the beasts of the jungle would not
deign to possess - money to purchase the effeminate pleasures of
weaklings. And yet withal bound down by silly customs that make them
slaves to their unhappy lot while firm in the belief that they be the
lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
