[GRASS-dev] Re: [GRASS GIS] #528: wxGUI cmd: r.mapcalc fails
(quoting + args with spaces)
trac at osgeo.org
Sun May 24 01:07:01 EDT 2009
#528: wxGUI cmd: r.mapcalc fails (quoting + args with spaces)
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by hamish):
Replying to [comment:15 martinl]:
> Modified path applied in trunk (r37395), devbr6 (r37396) and relbr64
(r37397).
thanks.
> Testing welcomed ...
* autoparsing is nice in theory but slows things down and breaks for non-
grass commands. e.g. "ls -l" or "gdalinfo --version"
* left and right arrows don't work to move the cursor
in the terminal:
ls: unrecognised option `--interface-description'
Try `ls --help' for more information.
in the Command output tab:
self._module = menuform.GUI().ParseInterface(cmd = cmd)
File "/usr/src/grass/svn/develbranch_6/dist.i686-pc-linux-
gnu/etc/wxpython/gui_modules/menuform.py", line 1809, in
ParseInterface
xml.sax.parseString(getInterfaceDescription(cmd[0]).decode(e
nc).encode("utf-8"),
gnu/etc/wxpython/gui_modules/menuform.py", line 1769, in
raise IOError, _("Unable to fetch interface description for
command '%s'.") % cmd
IOError
Unable to fetch interface description for command 'ls'.
gdalinfo --version:
File "/usr/lib/python2.5/xml/sax/xmlreader.py", line 123,
in parse
self.feed(buffer)
File "/usr/lib/python2.5/xml/sax/expatreader.py", line
211, in feed
self._err_handler.fatalError(exc)
File "/usr/lib/python2.5/xml/sax/handler.py", line 38, in
fatalError
raise exception
xml.sax._exceptions
SAXParseException
<unknown>:1:0: syntax error
Ticket URL: <https://trac.osgeo.org/grass/ticket/528#comment:16>
