[GRASS-dev] Re: [GRASS GIS] #528: wxGUI cmd: r.mapcalc fails (quoting + args with spaces)
GRASS GIS trac at osgeo.org
Sun May 24 01:17:17 EDT 2009
  Reporter:  neteler   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by hamish):
 also when typing in
 v.db.select roads where="label ~ ...
 you get an error:
 raw = self.read_token()
   File "/usr/lib/python2.5/shlex.py", line 172, in
 read_token
 raise ValueError, "No closing quotation"
 ValueError
 can auto-completion be restricted to only run if you press the tab key?
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/528#comment:17>
