[GRASS-dev] Re: [GRASS GIS] #614: r.proj method=cubic_f passes nulls
GRASS GIS trac at osgeo.org
Mon May 25 12:02:42 EDT 2009
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  6.4.0
 Component:  Raster  |     Version:  svn-develbranch6
Resolution:          |    Keywords:  r.proj
  Platform:  Linux   |         Cpu:  x86-32
Comment (by kyngchaos):
 Since cubic_f is essentially a patch of cubic,bilinear,nearest, only nulls
 left from nearest should pass thru (propagate).
 ...testing...
 Looks like it happens with cubic, bilinear AND nearest also.  So it's not
 the fallback logic.
Ticket URL: <https://trac.osgeo.org/grass/ticket/614#comment:2>
