[GRASS-dev] Re: [GRASS GIS] #616: TIFFMergeFieldInfo not found
GRASS GIS trac at osgeo.org
Thu May 28 06:38:24 EDT 2009
  Reporter:  djj007        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  default       |     Version:  unspecified
Resolution:                |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 is this the OSGeo4W installer or the stand-alone one?
 (you are missing the libtiff library; or it it has gone out of date with
 the one that was used to build your copy of grass; or your system is using
 a copy of it already installed on your system from something else instead
 of the one that ships with grass)
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/616#comment:1>
