[GRASS-dev] [GRASS GIS] #617: r.sim.water crashes on WinGrass
GRASS GIS trac at osgeo.org
Thu May 28 07:46:29 EDT 2009
 Reporter:  hamish                 |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                 |      Status:  new
 Priority:  normal                 |   Milestone:  6.4.0
Component:  Raster                 |     Version:  6.4.0 RCs
 Keywords:  wingrass, r.sim.water  |    Platform:  MSWindows XP
      Cpu:  x86-32                 |
 As reported on grass-user by Bernd Tyrna:
 (I can reproduce it on wingrass using the spearfish.sh test script in the
 source dir; on linux it is fine)
 Hello!
 Has anyone experience with using r.sim.water under Windows? I'm planning
 to
 use it for the simulation of flash flood events.
 I tried it with a DEM (1m resolution) with the following region setting:
 g.region -p
 rojection: 99 (Transverse Mercator)
 zone:       0
 datum:      potsdam
 ellipsoid:  bessel
 north:      5377000.5
 south:      5375999.5
 west:       3502999.5
 east:       3504000.5
 nsres:      1
 ewres:      1
 rows:       1001
 cols:       1001
 cells:      1002001
 I calculated the first order partial derivative dx and dy with
 r.slope.aspect
 (Do I have to use degrees in the settings?)
 Leaving everything else unchanged for a testrun, I get the following
 message
 and r.sim.water crashes:
 "r.sim.water.exe hat ein Problem festgestellt und muss beendet werden."
 ("r.sim.water.exe has detected a problem and has to be closed")
 Can anyone tell me what's going wrong? Would it be better to use GRASS
 under
 Linux for this purpose?
 Thanks for your help,
 Bernd
 with "g.gisenv set="DEBUG=3" set I can see that it happens after "Running
 MAY 10 version," text. Next step in the program after that is to allocate
 memory...... so I'm guessing it's a malloc problem that is only triggered
 on windows, much like we saw in r.los in bug #111 (and I expect we'll see
 a lot more of these).
 valgrind running now (slow),
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/617>
