[GRASS-dev] GRASS 6 swig compile error
Markus Neteler neteler at osgeo.org
Fri May 29 12:53:54 EDT 2009
On Fri, May 29, 2009 at 4:58 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> after the recent update I can no longer compile the GRASS 6 SWIG interface
>> Apparently GMATHlib isn't found? (it is compiled)
>> Ah, or in 7 the headers are in
>>  grass70/include/gmath.h
>> while in 6 they are in
>>  grass6/include/gisdefs.h
>> Swig seems to get that wrong... need to move the declarations?
> This was changed in r35274:
>        http://trac.osgeo.org/grass/changeset/35274
I see... (somewhat)
> It's no coincidence that r35275 (which was comitted less than two
> minutes later) was the one which added the SWIG files for the other
> libraries:
>        http://trac.osgeo.org/grass/changeset/35275
> Hmm; you could probably just add $(GMATHLIB) to grass_LIBS, but that
That helps but ends in
/home/neteler/grass64/swig/python/raster_wrap.c:3777: undefined
reference to `unlock_driver'
Adding $(RASTERLIB) won't solve that.
> means that anything which wants to use libgis from Python ends up
> pulling in the gmath library, possibly along with BLAS/LAPACK and
> FFTW. And BLAS/LAPACK can have some fairly obscure issues related to
> gcc's Fortran support.
That's definitely undesired...
Markus
