[GRASS-dev] Re: v.autokrige
Anne Ghisla a.ghisla at gmail.com
Sat May 30 05:54:33 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
E. Jorge Tizado ha scritto:
> Hi Anne,
> I also find how krige a map but I fail trying export to a new raster map from
> R. The problem to test your module is that I use bash, not ksh. Migration to
> python is ideal.
> You comment documentation, see: "Applied Spatial Data Analysis with R", this
> is very interesting to learn about krige using R.
> Also you must explain the packages needed by R to run your module
Hi Jorge,
I'm sorry but I'm not the author of v.autokrige bash script, for
problems with that module you should contact the actual author Mathieu
Grelier: greliermathieu AT gmail.com
The new wxPython module is called v.autokrige2, available on SVN GRASS
assons repo. It will be a major rewrite, so I'll be pleased to receive
feedback from you.
> Good luck
> Jorge
best regards,
Anne
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkohAlkACgkQzZ3g4YwFFgZh+ACfau8GrRQjQ8pIMnVUCqgn4foR
EBYAnAwKBP0z1u4Vlh/6TC3l+If+XgYy
=aOBy
-----END PGP SIGNATURE-----
