[GRASS-dev] v.autokrige
E. Jorge Tizado
ejtizado at ono.com
Fri May 29 15:17:36 EDT 2009
Hi Anne,
I also find how krige a map but I fail trying export to a new raster map from
R. The problem to test your module is that I use bash, not ksh. Migration to
python is ideal.
You comment documentation, see: "Applied Spatial Data Analysis with R", this
is very interesting to learn about krige using R.
Also you must explain the packages needed by R to run your module
Good luck
Jorge
Dr. E. Jorge Tizado
Dpt. Biodiversity and Environmental Management
University of León
