[GRASS-dev] Re: [GRASS GIS] #623: compiling error grass6-devel -
winvista 32
trac at osgeo.org
Sat May 30 19:04:03 EDT 2009
#623: compiling error grass6-devel - winvista 32
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords:
Platform: MSWindows Vista | Cpu: Unspecified
Comment (by hellik):
Replying to [comment:4 hellik]:
> Replying to [comment:3 hamish]:
> > Replying to [comment:2 hellik]:
> > > Errors in:
> > > /c/osgeo4w/usr/src/grass6_devel/gui/scripts
> > > /c/osgeo4w/usr/src/grass6_devel/gui/wxpython/scripts
> > > /c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.daemon
> > ok, I think I've fixed all three of those now.
> > can you 'svn up' and try once again?
> > Hamish
> Hi,
> a fresh svn-checkout at rev37638, no compiling error anymore:
> GRASS GIS compilation log
> Started compilation: Sat May 30 21:51:23 GMT 2009
> Errors in:
> No errors detected.
> Finished compilation: Sat May 30 22:43:44 GMT 2009
> but what does this mean (automatically startet by the package.sh in the
osgeo4w-directory after compilation)- there are some error messages
> Sat May 30 22:43:44 GMT 2009: STARTING make install
> echo /c/osgeo4w/usr/src/grass6_devel/bin.i686-pc-mingw32/grass65
> make[1]: Entering directory `/c/osgeo4w/usr/src/grass6_devel'
> test -d /c/OSGeo4W/apps/grass/grass-6.5.svn || mkdir -p -m 755
> test -d /c/OSGeo4W/apps/grass/bin || mkdir -p -m 755
> sed -e "s#^GISBASE.*#GISBASE=/c/OSGeo4W/apps/grass/grass-6.5.svn#"
/c/osgeo4w/usr/src/grass6_devel/bin.i686-pc-mingw32/grass65 >
/c/OSGeo4W/apps/grass/bin/grass65
> chmod a+x /c/OSGeo4W/apps/grass/bin/grass65
> sed -e "s#WINGISBASE=.*#WINGISBASE=/c/OSGeo4W/apps/grass/grass-6.5.svn#"
/c/osgeo4w/usr/src/grass6_devel/bin.i686-pc-mingw32/grass65.bat >
/c/OSGeo4W/apps/grass/bin/grass65.bat
> chmod a+x /c/OSGeo4W/apps/grass/bin/grass65.bat
> cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf -
AUTHORS COPYING CHANGES REQUIREMENTS.html GPL.TXT | (cd
/c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
> cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - bin
| (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
bwidget | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - )
2>/dev/null
> cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - docs
driver | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
> cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - etc
fonts | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
> cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - man
> tar: man: Cannot stat: No such file or directory
> tar: Error exit delayed from previous errors
scripts | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - )
2>/dev/null
> if [ 1 -eq 1 ] ; then cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
mingw32 ; tar cBf - locale | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar
xBf - ) 2>/dev/null ; fi
> tar: locale: Cannot stat: No such file or directory
include | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - )
2>/dev/null
> cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - lib
> sed 's#'/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
mingw32'#'/c/OSGeo4W/apps/grass/grass-6.5.svn'#g'
/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/monitorcap >
/c/OSGeo4W/apps/grass/grass-6.5.svn/etc/monitorcap
/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/fontcap >
/c/OSGeo4W/apps/grass/grass-6.5.svn/etc/fontcap
> chmod -R a+rX /c/OSGeo4W/apps/grass/grass-6.5.svn 2>/dev/null
> tar cBf - gem/skeleton | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn/etc ;
> /bin/install -c gem/gem6 /c/OSGeo4W/apps/grass/bin 2>/dev/null
> make[1]: [real-install] Error 1 (ignored)
> make[1]: Leaving directory `/c/osgeo4w/usr/src/grass6_devel'
> Sat May 30 22:45:27 GMT 2009: END
i've checked
in C:\OSGeo4W\apps\grass\bin there is grass65 and grass65.bat
and C:\OSGeo4W\apps\grass\grass-6.5.svn
best regards
helli
Ticket URL: <http://trac.osgeo.org/grass/ticket/623#comment:5>
