[GRASS-dev] Re: [GRASS GIS] #623: compiling error grass6-devel - winvista 32
GRASS GIS trac at osgeo.org
Sat May 30 19:11:40 EDT 2009
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  normal           |   Milestone:  6.5.0
 Component:  default          |     Version:  svn-develbranch6
Resolution:                   |    Keywords:
  Platform:  MSWindows Vista  |         Cpu:  Unspecified
Comment (by hellik):
 Replying to [comment:5 hellik]:
 > Replying to [comment:4 hellik]:
 > > Replying to [comment:3 hamish]:
 > > > Replying to [comment:2 hellik]:
 > > > > Errors in:
 > > > > /c/osgeo4w/usr/src/grass6_devel/gui/scripts
 > > > > /c/osgeo4w/usr/src/grass6_devel/gui/wxpython/scripts
 > > > > /c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.daemon
 > > > ok, I think I've fixed all three of those now.
 > > > can you 'svn up' and try once again?
 > > > Hamish
 > > Hi,
 > > a fresh svn-checkout at rev37638, no compiling error anymore:
 > > GRASS GIS compilation log
 > > Started compilation: Sat May 30 21:51:23 GMT 2009
 > > Errors in:
 > > No errors detected.
 > > Finished compilation: Sat May 30 22:43:44 GMT 2009
 > > but what does this mean (automatically startet by the package.sh in
 the osgeo4w-directory after compilation)- there are some error messages
 > > Sat May 30 22:43:44 GMT 2009: STARTING make install
 > > echo /c/osgeo4w/usr/src/grass6_devel/bin.i686-pc-mingw32/grass65
 > > make[1]: Entering directory `/c/osgeo4w/usr/src/grass6_devel'
 > > test -d /c/OSGeo4W/apps/grass/grass-6.5.svn || mkdir -p -m 755
 > > test -d /c/OSGeo4W/apps/grass/bin || mkdir -p -m 755
 > > sed -e "s#^GISBASE.*#GISBASE=/c/OSGeo4W/apps/grass/grass-6.5.svn#"
 /c/osgeo4w/usr/src/grass6_devel/bin.i686-pc-mingw32/grass65 >
 /c/OSGeo4W/apps/grass/bin/grass65
 > > chmod a+x /c/OSGeo4W/apps/grass/bin/grass65
 > > sed -e
 "s#WINGISBASE=.*#WINGISBASE=/c/OSGeo4W/apps/grass/grass-6.5.svn#"
 /c/osgeo4w/usr/src/grass6_devel/bin.i686-pc-mingw32/grass65.bat >
 /c/OSGeo4W/apps/grass/bin/grass65.bat
 > > chmod a+x /c/OSGeo4W/apps/grass/bin/grass65.bat
 > > cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf -
 AUTHORS COPYING CHANGES REQUIREMENTS.html GPL.TXT | (cd
 /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
 bin | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
 bwidget | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - )
 2>/dev/null
 docs | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
 driver | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
 etc | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
 fonts | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
 man | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
 > > tar: man: Cannot stat: No such file or directory
 > > tar: Error exit delayed from previous errors
 scripts | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - )
 2>/dev/null
 > > if [ 1 -eq 1 ] ; then cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
 mingw32 ; tar cBf - locale | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar
 xBf - ) 2>/dev/null ; fi
 > > tar: locale: Cannot stat: No such file or directory
 include | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - )
 2>/dev/null
 lib | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
 > > sed 's#'/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
 mingw32'#'/c/OSGeo4W/apps/grass/grass-6.5.svn'#g'
 /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/monitorcap >
 /c/OSGeo4W/apps/grass/grass-6.5.svn/etc/monitorcap
 /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/fontcap >
 /c/OSGeo4W/apps/grass/grass-6.5.svn/etc/fontcap
 > > chmod -R a+rX /c/OSGeo4W/apps/grass/grass-6.5.svn 2>/dev/null
 > > tar cBf - gem/skeleton | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn/etc ;
 > > /bin/install -c  gem/gem6 /c/OSGeo4W/apps/grass/bin 2>/dev/null
 > > make[1]: [real-install] Error 1 (ignored)
 > > make[1]: Leaving directory `/c/osgeo4w/usr/src/grass6_devel'
 > > Sat May 30 22:45:27 GMT 2009: END
 > i've checked
 > in C:\OSGeo4W\apps\grass\bin there is grass65 and grass65.bat
 > and C:\OSGeo4W\apps\grass\grass-6.5.svn
 > best regards
 > helli
 following http://trac.osgeo.org/grass/wiki/CompileOnWindows:
 1. Open C:\OSGeo4W\apps\grass\bin\grass64 and at line 24 add:
 if [ -z "$PYTHONPATH" ] ; then
  PYTHONPATH="$GISBASE/etc/python"
 else
  PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
 fi
 export PYTHONPATH
 2. To start grass, type in MSYS console:
 /osgeo4w/apps/grass/bin/grass64
 Or to use the new wxpython GUI:
 /osgeo4w/apps/grass/bin/grass64 -wxpython
 grass is starting
Ticket URL: <http://trac.osgeo.org/grass/ticket/623#comment:6>
