[GRASS-dev] Re: [GRASS GIS] #623: compiling error grass6-devel -
winvista 32
trac at osgeo.org
Sun May 31 02:50:25 EDT 2009
#623: compiling error grass6-devel - winvista 32
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: normal | Milestone: 6.5.0
Component: default | Version: svn-develbranch6
Resolution: fixed | Keywords:
Platform: MSWindows Vista | Cpu: Unspecified
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Comment:
i think that the ticket can be closed, because the original problem, the
compiling error on windows, seems to be solved.
maybe the wiki-site http://trac.osgeo.org/grass/wiki/CompileOnWindows
should be updated at point "When finished, you should have the following
compilation log (c:\osgeo4w\usr\src\grass-6.4xxx\error.log): ..." to
reflect the actual situation with no compiling errors, even though this
thread was about develbranch6?
at the moment i'm able to test the self compiled grass6devel.
Best regards
Helli
Ticket URL: <http://trac.osgeo.org/grass/ticket/623#comment:9>
