[GRASS-dev] Re: [GRASS GIS] #623: compiling error grass6-devel - winvista 32
GRASS GIS trac at osgeo.org
Sun May 31 06:33:47 EDT 2009
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  closed
  Priority:  normal           |   Milestone:  6.5.0
 Component:  default          |     Version:  svn-develbranch6
Resolution:  fixed            |    Keywords:
  Platform:  MSWindows Vista  |         Cpu:  Unspecified
Comment (by hamish):
 Hamish:
 > they've removed even more stuff from the bin/grass64(.sh) script
 > so even if the GUI starts there may be other problems.
 Sorry, I speak terrible lies. They have done no such thing.
 I was confused though why setting PYTHONPATH is needed before
 the grass64 script runs Init.sh, as Init.sh does just that as
 one of its first tasks. BUT that contained an error.
 Fixed in SVN and  http://trac.osgeo.org/grass/wiki/CompileOnWindows
 updated (I fixed/simplified a few other things there too).
 Helli:
 > maybe the wiki-site http://trac.osgeo.org/grass/wiki/CompileOnWindows
 > should be updated at point "When finished, you should
 > have the following compilation log
 > (c:\osgeo4w\usr\src\grass-6.4xxx\error.log): ..."
 > to reflect the actual situation with no compiling errors,
 > even though this thread was about develbranch6?
 done.
 > at the moment i'm able to test the self compiled grass6devel.
 great. Can you tell me if Config -> Manage GRASS working enviro ->
 Change Default GUI works? (restart grass65 without options or
 run g.gisenv from the command prompt to check)
 Can you also test if 'Cmd> ' works from the wxGUI and if
 '[Run in DOS box]' now works from the Tcl/Tk GUI Output window?
 cheers,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/623#comment:10>
