[GRASS-dev] Re: [GRASS GIS] #623: compiling error grass6-devel - winvista 32
GRASS GIS trac at osgeo.org
Sun May 31 15:10:57 EDT 2009
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  closed
  Priority:  normal           |   Milestone:  6.5.0
 Component:  default          |     Version:  svn-develbranch6
Resolution:  fixed            |    Keywords:
  Platform:  MSWindows Vista  |         Cpu:  Unspecified
Comment (by hellik):
 Replying to [comment:10 hamish]:
 fresh svn-ckeckout for develbranch6 at rev37660
 compiling and automatically installing with package.sh is now working
 without any error
 > Hamish:
 > great. Can you tell me if Config -> Manage GRASS working enviro ->
 > Change Default GUI works? (restart grass65 without options or
 > run g.gisenv from the command prompt to check)
   File
 "c:/OSGeo4W/apps/grass/grass-6.5.svn/etc/wxpython/wxgui.py",
 line 458, in OnMenuCmd
 menuform.GUI().ParseCommand(cmd, parentframe=self)
   File "c:\OSGeo4W\apps\grass\grass-6.5.svn\etc\wxpython\gui
 _modules\menuform.py", line 1710, in ParseCommand
 self.grass_task = self.ParseInterface(cmd)
 _modules\menuform.py", line 1678, in ParseInterface
 tree = etree.fromstring(getInterfaceDescription(cmd[0]).deco
 de(enc).encode("utf-8"))
 _modules\menuform.py", line 1640, in getInterfaceDescription
 raise IOError, _("Unable to fetch interface description for
 command '%s'.") % cmd
 IOError
 Unable to fetch interface description for command
 'g.change.gui.py'.
 > Hamish:
 > Can you also test if 'Cmd> ' works from the wxGUI
 for quick testing this, i follow
 [http://trac.osgeo.org/grass/wiki/HowToTestGrass6 HowToTestGrass6]. Maybe
 is it possible add line numbers in this txt-files to refer to at possible
 bugs?
 commands copied from grasstestrast.txt to 'Cmd>
 g.region rast=elevation -p => working
 d.rast elevation => raster is added in layer manager, but nothing is seen
 in map display (auto-rendering activated)
 d.his h_map=elevation i_map=elevation_shade => working, map displayed in
 map display
 r.info -r elevation => working
 d.rast landuse96_28m cat=1,2 bg=black => raster is added in layer manager,
 but nothing is seen in map display
 d.rast -o elevation val=100-160 => raster is added in layer manager, but
 r.cats landuse96_28m => working
 r.report landuse96_28m unit=c,h,p => working
 r.stats -pl zipcodes,landuse96_28m => working
 r.random.cells out=randomcells_200m distance=200 => working
 r.random.surface out=rand_surf_100m => working
 r.random.surface out=rand_surf_100m_d1000 distance=1000 => working
 commands copied from grasstestvect.txt to 'Cmd>
 g.region region=swwake_10m -p => working
 d.vect streams col=blue => vector is added in layer manager, but nothing
 d.vect.thematic -l censusblk_swwake column=HOUSEHOLDS nint=6 color=yellow-
 cyan => vector is added in layer manager, but nothing is seen in map
 display
 v.info schools_wake => working
 g.copy vect=soils_general,myvectmap => working
 v.support myvectmap scale=24000  => working
 v.db.connect -p schools_wake  => working
 v.info -c schools_wake  => working
 db.tables -p   => working
 v.db.select schools_wake where="CAPACITYTO > 300" => working
 v.extract -r schools_wake out=small_schools_wake => working
 g.copy vect=lakes,mylakes => working
 v.db.select mylakes => working
 v.db.select mylakes where="FTYPE IS NULL" => working
 v.db.update mylakes col=FTYPE value=WETLAND where="FTYPE IS NULL" =>
 working
 g.copy vect=geodetic_pts,mygeodetic_pts => working
 v.db.addcol mygeodetic_pts col="zval double precision" => working
 v.db.update mygeodetic_pts col=zval qcol="CAST(z_value AS double
 precision)" where="z_value <> 'N/A'"
 (Sun May 31 20:58:07 2009)
 v.db.update mygeodetic_pts col=zval qcol=CAST(z_value AS double precision)
 where=z_value <> 'N/A'
 DBMI-DBF driver error:
 ERROR: Error while executing: 'UPDATE mygeodetic_pts SET zval=CAST(z_value
 AS double precision) WHERE z_value <> N/A
 (Sun May 31 20:58:10 2009) Command finished (3 sec)
 echo "UPDATE mygeodetic_pts SET zval=NULL WHERE zval=0" | db.execute =>
 how can this be tested if command is executed
 v.db.select mygeodetic_pts col=Z_VALUE,zval => working
 > Hamish:
 > and if '[Run in DOS box]' now works from the Tcl/Tk GUI Output window?
 for testing this starting grass in the msys-shell
 with $ /osgeo4w/apps/grass/bin/grass65 -tcltk
 following error message:
 syringia at NADA /c/osgeo4w
 Cleaning up temporary files ...
 Starting GRASS ...
 GISDBASE='C:\gisdata\grassdata';
 LOCATION_NAME='nc_spm_08';
 MAPSET='user1';
 WARNING: Attention!
 WARNING: Locking is not supported on Windows!
 /c/OSGeo4W/apps/grass/grass-6.5.svn/scripts/gis.m:
 c:/osgeo4w/C:\OSGeo4W\bin\wi                          sh.exe: No such file
 or directory
 /c/OSGeo4W/apps/grass/grass-6.5.svn/scripts/gis.m: exec:
 c:/osgeo4w/C:\OSGeo4W\                          bin\wish.exe: cannot
 execute: No such file or directory
 /C:\OSGeo4W\bin\wish.exe is definitly there; also interesting that the
 tcltk-start-window for choosing the location is working, but gis.m is not
 best regards
 Helli
 p.s. for this testing should we open another thread, wiki, trac, mail,
 p.p.s maybe would there be a kind of a "test-suite" possible to avoid
 copying commands from to example-txt-files to wx-python-command-line?
Ticket URL: <http://trac.osgeo.org/grass/ticket/623#comment:11>
