[GRASS-dev] Re: [GRASS GIS] #623: compiling error grass6-devel - winvista 32
GRASS GIS trac at osgeo.org
Sun May 31 15:17:44 EDT 2009
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  closed
  Priority:  normal           |   Milestone:  6.5.0
 Component:  default          |     Version:  svn-develbranch6
Resolution:  fixed            |    Keywords:
  Platform:  MSWindows Vista  |         Cpu:  Unspecified
Comment (by neteler):
 Replying to [comment:11 hellik]:
 > fresh svn-ckeckout for develbranch6 at rev37660
 > > Hamish:
 > > great. Can you tell me if Config -> Manage GRASS working enviro ->
 > > Change Default GUI works? (restart grass65 without options or
 > > run g.gisenv from the command prompt to check)
    File "c:\OSGeo4W\apps\grass\grass-6.5.svn\etc\wxpython\gui
  _modules\menuform.py", line 1640, in getInterfaceDescription
  raise IOError, _("Unable to fetch interface description for
  command '%s'.") % cmd
  IOError
  Unable to fetch interface description for command
  'g.change.gui.py'.
 Note - see for similar error: trac #234, #553, #581
Ticket URL: <http://trac.osgeo.org/grass/ticket/623#comment:12>
