[GRASS-dev] Re: [GRASS GIS] #623: compiling error grass6-devel -
	winvista 32
    trac at osgeo.org
    Sun May 31 15:19:37 EDT 2009
#623: compiling error grass6-devel - winvista 32
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  closed
  Priority:  normal           |   Milestone:  6.5.0
 Component:  default          |     Version:  svn-develbranch6
Resolution:  fixed            |    Keywords:
  Platform:  MSWindows Vista  |         Cpu:  Unspecified
Comment (by neteler):
 Replying to [comment:11 hellik]:
 > v.db.update mygeodetic_pts col=zval qcol="CAST(z_value AS double
 precision)" where="z_value <> 'N/A'"
 (Sun May 31 20:58:07 2009)
 v.db.update mygeodetic_pts col=zval qcol=CAST(z_value AS double precision)
 where=z_value <> 'N/A'
 DBMI-DBF driver error:
 ERROR: Error while executing: 'UPDATE mygeodetic_pts SET zval=CAST(z_value
 AS double precision) WHERE z_value <> N/A
 (Sun May 31 20:58:10 2009) Command finished (3 sec)
 Note: CAST is not supported by DBF driver, so you need to use SQLite,
 PostgreSQL or MySQL to use CAST.
Ticket URL: <http://trac.osgeo.org/grass/ticket/623#comment:13>
