[GRASS-dev] Re: [GRASS GIS] #799: Add -o option to muliple import of GDAL data
GRASS GIS trac at osgeo.org
Tue Nov 3 03:33:28 EST 2009
  Reporter:  trochtaj     |       Owner:  martinl
      Type:  enhancement  |      Status:  assigned
  Priority:  normal       |   Milestone:  6.4.0
 Component:  wxGUI        |     Version:  unspecified
Resolution:               |    Keywords:  import, multi
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by mmetz):
 Replying to [comment:1 martinl]:
 > Please try r39669 (devbr6). Not sure if to backported it into relbr64
 (it's not bugfix). Probably in GRASS 6.4 we can just set {{{-o}}} as
 default also for {{{v.in.ogr}}}.
 Just for clarification, the -o flag means "Override dataset projection
 (use location's projection)", same like in r.in.gdal. Thus your suggestion
 to set -o as default means override dataset projection by default?
 The new wxGUI dialog is not consistent with regard to OGR layers and OGR
 datasources, for e.g. *.gpx and *.kml files, datasources are listed as
 layers, although these datasources hold layers themselves. With so many
 different supported OGR formats, I would strongly opt to at least stick to
 the terminology used by OGR in regard to what is a datasource and what is
 a layer to avoid user confusion.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/799#comment:4>
